Revit 2015 macro problem
I am trying to create a macro for my friend. However, we could not figure out why revit does not allow us to create macro in macro management menu. It can create a module, but when it comes to macro there is no luck. Here is some information what we have.
Revit version: 2015 - Student edition
OS: Windows 10
Macro menuMacro menu
In order to find a solution about this, which steps should i follow ?
Thanks.
By clicking on macro its just create for you a function in side your class , so click edit, and  just put this function in side the class
public void Main()
// Your code here
then rebuild your code.
That is the problem. Even i could code and build the macro, revit does not run it. No matter what it just says: "Loading the macro failed. Rebuilding the module may resolve the issue."
ok  try to use application instead of macro
