I would suggest retrieving all database ElementType objects with the category Toposolid and using one of those. That is the most common method to populate such a type id argument.
If your document lacks a Toposolid type, it may be impossible to create a new Toposolid. Try it out manually in the UI and see whether it works. However, I doubt that it is possible to remove all Toposolid types from a Revit 2024 RVT project. I would assume that they are built-in, hardwired.
