scaffolding
scaffolding
nitin2BXR5
scaffolding
nitin2BXR5
in which autodesk  software I can design scaffolding in 3d with load calculation .
jeremy_tammik
Please ask this question in a product and end user oriented forum. This is the wrong place for it.
Unfortunately, this is not the best place to ask such a question. Please note that this discussion forum is dedicated to programming Revit using the Revit API. Afaict from your query/description and screen snapshot, you are not doing anything programmatically yourself using the Revit API, just using the standard Revit user interface. In that case, you will probably get more optimal answers to a question like yours relating to product setup, optimisation, usage, best practices and other end-user support issues in one of the non-API Revit product support discussion forums instead:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are better equipped to address this topic than us programming nerds.
I hope this clarifies. Thank you for your cooperation and understanding.
Best regards,
Jeremy
jeremy_tammik
Furthermore, you could always consider searching for an answer on the Internet yourself, e.g., like this:
There do seem to be a couple of non-Autodesk Revit add-ins that support that kind of stuff...
