How to get the relationship between FamilyInstance of light fixture and LightNod
Is there some relationship between FamilyInstance of light fixture and LightNod, and how to get it?
With below codes I can get LightingFixture object, but I can't advance to get the relationship between FamilyInstance of light fixture and LightNod.
            Element element = m_doc.GetElement(elementId);
            string element_category = element.Category.Name;
            if (element_category == "Lighting Fixtures")
                FamilyInstance light = element as FamilyInstance;
                LightingFixture lightFxiture = light.MEPModel as LightingFixture;
Can anyone give some help?
Thanks in advance.
jeremytammik
There is no such thing as a LightNod in the Revit API.
Please be careful with spell checking, especially in the title of a thread.
The LightNode class is generated by the custom exporter functionality:
https://www.revitapidocs.com/2020/3904e399-f67a-a111-d963-5f91665b233c.htm
If you implement a custom exporter, it will generate the LightNode class for you and the association with the family instance will be obvious:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.1
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Hi Jeremy,
Thank you very much for your help.
I made a typo in this question. LightNod should be LightNode.
I've read the pages you supplied to me about light, and I still don't know the association between family instance of light fixture and LightNode.
Can I get LightNode object from family instance of light fixture or can I get family instance of light fixture from LightNode object?
If not, how can I get LightNode object from family instance of light fixture?
Thanks again.
