Cant understand how external event works.
Hi everyone I am new to the Forum and to programming as well I work with dynamo to accomplish most of my required tasks and now diving into programming and C#,so kindly bear with me if my questions are so primitive.
I am trying to create a form that can import a sketch up model into my revit file for further development.
I  am Stuck with the error that says " Cannot access transaction outside API context" and with other posts and forum I understand that the Revit API lives in a special thread and can be accessed via other thread..
Here is what I have done :
SKP_importer.cs file:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
namespace Skp2Rvt
    [Transaction(TransactionMode.Manual)]
    [Regeneration(RegenerationOption.Manual)]
    public class SKP_Importer : IExternalCommand
        public static Document doc;
        public static Application uiapp;
        public static UIDocument UIdoc;
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            var app = commandData.Application;
            uiapp = app.Application;
            UIdoc = app.ActiveUIDocument;
            doc = UIdoc.Document;
            var UIF = new Form1();
            UIF.Show();
            return Result.Succeeded;
        public void AddSkp(string file)
            using (Transaction ts = new Transaction(doc, "test"))
                var optionSKP = new SKPImportOptions();
                    Transaction trans = new Transaction(doc, "Import SKP file");
                    trans.Start();
                    var ActiveView = doc.ActiveView;
                    var SKP_File_Id = doc.Import(file, optionSKP, ActiveView);
                    var SKP_file = doc.GetElement(SKP_File_Id);
                    var list = new List<ElementId>();
                    list.Add(SKP_File_Id);
                    UIdoc.Selection.SetElementIds(list);
                    trans.Commit();
   //Here Iam trying to create an external command that can be called from my form button.
   // the biggest problem is i am not able to add overload parameters to the methods.
    public class Addfile : IExternalEventHandler
        public void Execute(UIApplication app)
                    trans.Start();
                    trans.Commit();
        public string GetName()
            throw new NotImplementedException();
Form1 file :
using System;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
namespace Skp2Rvt
    public partial class Form1 : Form
        public string FileLocation = "";
        public Form1()
            InitializeComponent();
        private void BrowseButton_Click(object sender, EventArgs e)
            // Create OpenFileDialog
            Microsoft.Win32.OpenFileDialog openFileDlg = new Microsoft.Win32.OpenFileDialog();
            var result = openFileDlg.ShowDialog();
            if (result == true)
                FileName.Text = openFileDlg.FileName;
        private void button1_Click(object sender, EventArgs e)
            FileLocation = FileName.Text;
            var skp = new SKP_Importer();
            skp.AddSkp(FileLocation);
Creating a external event was a smaller problem and the biggest problem is that Iam not able to add parameters to my methods in the external command.
please help me complete this.
RPTHOMAS108
The below files within the samples folder of the SDK below should be your starting point, I make bold the objects that fit the description of your task best.
https://www.autodesk.com/developer-network/platform-technologies/revit
These files contain content of 'IExternalEvent'
...\Samples\WinderStairs\CS\WinderUpdater.cs
...\Samples\PostCommandWorkflow\CS\PostCommandRevisionMonitor.cs
...\Samples\ModelessDialog\ModelessForm_ExternalEvent\CS\RequestHandler.cs
...\Samples\GetSetDefaultTypes\CS\DefaultElementTypes.xaml.cs
...\Samples\DockableDialogs\CS\ExternalEvents\APIExternalEventHandler.cs
This file from SDK contains content of 'Interlocked.Exchange' (passing objects via arguments in threadsafe way).
Note that more recently alternative approaches have been put forward and perhaps you would eventually find those preferable:
https://thebuildingcoder.typepad.com/blog/2020/03/another-async-await-rex-and-structural-analysis-sd...
Thank you so much, I dint Understand this initially I had to read about concepts of external events and how it works to make it work, thanks for pointing me in the right direction.!
I am attaching the code here just in case if you or anybody else can show me a shorter way of doing this.
namespace Skp2Rvt
    public class SKP_Importer_command : IExternalCommand
        public static Document doc = null;
        public static UIApplication application = null;
            IExternalEventHandler handler_event = new SkpImporter_EventHandler();
            ExternalEvent exEvent
              = ExternalEvent.Create(handler_event);
            application = commandData.Application;
            doc = application.ActiveUIDocument.Document;
            var form = new Form1(exEvent);
            form.Show();
    public class SkpImporter_EventHandler : IExternalEventHandler
        public void Execute(UIApplication uiapp)
            UIDocument uidoc = uiapp.ActiveUIDocument;
            if (null == uidoc)
                return; // no document, nothing to do
            Document doc = uidoc.Document;
            using (Transaction tx = new Transaction(doc,"My event"))
                try
                    trans.Start();
                    var file = Form1.FileLocation;
                    uidoc.Selection.SetElementIds(list);
                    trans.Commit();
                catch
                    TaskDialog.Show("Error", "Something went wrong with the import,please check the version of SKP file.");
            return "my event";
Kennan.Chen
I created the Revit.Async library to make the use of external event natural. In the repository I also prepared some material about how external event works and how Revit.Async handle the job.
 Hope it helps.
KennanChan/Revit.Async: Use task-based asynchronous pattern (TAP) to run Revit API code from any exe...
