How to get the bounding segments of a room?
I am using the following code: I am trying to  get all the bounding segments of each room. But the list is not getting populated by the method of the Rooms class.
room.GetBoundarySegments(boundaryOptions);
private List<int> GetElementIdsOfWallsEnclosingRooms()
            List<int> elementIdsOfWalls = new List<int>();
            Document doc = commandData.Application.ActiveUIDocument.Document;
            FilteredElementCollector collector = new FilteredElementCollector(doc);
            collector.OfCategory(BuiltInCategory.OST_Rooms);
            IList<IList<BoundarySegment>> boundarySegments;
            foreach (Room room in collector)
                SpatialElementBoundaryOptions boundaryOptions = new SpatialElementBoundaryOptions();
                boundaryOptions.SpatialElementBoundaryLocation = SpatialElementBoundaryLocation.CoreCenter;
                boundaryOptions.StoreFreeBoundaryFaces = true;
boundarySegments = room.GetBoundarySegments(boundaryOptions); IList<BoundarySegment> boundarySegmentList = boundarySegments.ElementAt(0); foreach (BoundarySegment boundarySegment in boundarySegmentList) { elementIdsOfWalls.Add(boundarySegment.ElementId.IntegerValue); } } return elementIdsOfWalls; }
Is there any problem with SpecialElementBoundaryOptions?
The value inside boundarySegments has 0 lists.
I think it is because you aren't looping through every List in the List (sounds confusing, I know).
replace your loop with this:
// IList<BoundarySegment> boundarySegmentList = boundarySegments.ElementAt(0);
foreach(IList<BoundarySegment> boundarySegmentList in boundarySegments)
{ foreach (BoundarySegment boundarySegment in boundarySegmentList) { elementIdsOfWalls.Add(boundarySegment.ElementId.IntegerValue); }
