difference between ElementTransformUtils.RotateElement and Location.Rotate
dirk.neethling
dirk.neethling
what is the difference between applying
ElementTransformUtils.RotateElement(doc, fi, axis, angle)
and
fi.Location.Rotate(axis, angle)
to a FamilyInstance?
dirk
Dear Dirk,
As  notice I guess the basic difference between in term of work:
 fi.Location.rotate : Rotate element with their dependent element. Suppose B element attached with A if you use Location.Rotate(A) it rotate B also. While ElementTransfomUtil rotate only specified element.
You can also see their metadata summary.
