FamilyInstance fails to properly locate instance
dirk.neethling
dirk.neethling
I have a XYZ coordinate, pnt, with the value
+  pnt {(0.000000000, 0.000000000, -9.842519685)}
where I want to locate a FamilyInstance. When I run
fiSegment = doc.Create.NewFamilyInstance(pnt, segmentSymbol, Autodesk.Revit.DB.Structure.StructuralType.NonStructural);
the instance is located at XYZ={0,0,0} instead of pnt.
When I try to correct this using the code below, the result is that the element is now located at
+  segment_pnt {(0.000000000, 0.000000000, -19.685039370)}
What am I doing wrong?
segment_referencePoint = doc.GetElement(fiSegment.Id) as ReferencePoint;
segment_locpnt = fiSegment.Location as LocationPoint;
segment_pnt = segment_locpnt.Point;
//move segment to where the ring is
trans1 = pnt - segment_pnt;
XYZ location = app.Create.NewXYZ(0, 0, pnt.Z);
ElementTransformUtils.MoveElement(doc, fiSegment.Id, location);
//doc.m.Move(items[i], app.Create.NewXYZ( 0, 0, elevations[i]));
dirk
Revitalizer
Hi Dirk,
in the Family file, is the BuiltInParameter.FAMILY_WORK_PLANE_BASED parameter enabled ?
"Arbeitsebenenbasiert" in German.
If so, you can use the FamilyInstance's BuiltInParameter.INSTANCE_FREE_HOST_OFFSET_PARAM to adjust the elevation over the work plane.
Its German display name is "Versatz".
Revitalizer
Edit:
If your Family is not work plane based, the FamilyInstance's offset parameter is meaningless.
Rudolf Honke
Software Developer
Mensch und Maschine
dirk.neethling
Thanks Revitalizer,
I managed to set both BuiltInParameters in the FamilyDocument and instance respectively.
Can I now utilise the following methods?
ElementTransformUtils.RotateElement
Using them to manipulate a FamilyInstance does not seem to yield the same results as using them to modify an instance of an Adaptive  model, obtained from ,
AdaptiveComponentInstanceUtils.CreateAdaptiveComponentInstance(doc, symbol);
When I run These methods over the Family instance, the resulting Position and orientation of that instance is different to the instance created using the AdaptiveComponentInstanceUtils class.
regards, dirk
dirk.neethling
The familyInstancenNeeds to be rotated about all 3 axes, and around ist center axis.
When I use plane-based Elements it Fails. Even when I use the template "M_Mechanische Geräte.rft", and uncheck the BuiltInParameter FAMILY_ALWAYS_VERTICAL, it fails. It seems that in Revit it is impossible to instantiate and then rotate an Element around the 3 axis of a coordinate System. There is always something illogical at Play.
