View Filter Order
View Filter Order
View Filter Order
I wrote a plugin that can copy view filter settings (Name, visibility, projection / surface etc.), however I cannot seem to access the original order, and unfortunately the filters are not stored in the correct order.
I found a post from a few years ago that was aware of this problem. I am hoping this has been fixed, it is literally one int value to add to the api. Here is the original post:
https://forums.autodesk.com/t5/revit-api-forum/view-filter-order/td-p/5003890
Any help?
- Jed
jeremytammik
Dear Jed,
The wishlist item CF-1486 [Need API to order the view filters on a view] that was raised based on the original thread ended up being closed again, since the original requester said it was of little importance to him.
I suggest you do two things:
  • Submit this as an entry in the Revit Idea Station and ensure it gets many votes. Maybe it is already in there?
  • Submit a business case explaining the importance of this wish for you, your customers, the community, Autodesk, your revenue, etc. to underline its importance.
I hope this helps.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
