How to get SteelProxyElement geometry
I try to acces to the geometry of a SteelProxyElement.
To do this i use  this portion of code
        IOrderedEnumerable<Element> GetAllModelElements(Document doc)
            List<Element> elements = new List<Element>();
            FilteredElementCollector collector
              = (FilteredElementCollector)new FilteredElementCollector(doc)
              .WhereElementIsNotElementType();
            Options options = new Options();
            if (null != options)
                options.ComputeReferences = true;
                options.DetailLevel = ViewDetailLevel.Fine;
            foreach (Element e in collector)
                if ((e.Category!=null) &&(e.Category.Name.ToUpper()=="PLATINES"))
                    elements.Add(e);
                if (e.get_Geometry(options) != null)
                    elements.Add(e);
            return elements.OrderBy(e => e.Category.Name);
e.get_Geometry return null for SteelProxyElement why ?
Fred
jeremy_tammik
I am not familiar with steel proxy elements. A proxy is a placeholder. Maybe the placeholder has no own geometry? Have you explored the elements, its geometry, properties and relationships with RevitLookup and other tools.
Yes, here a screen copy.
but the get_Geometry(_opt) return always null. and i don't know why.
thanks for your answer.
heziTYJKR
Hi, did you find a solution for that? I am also facing the same issue.
SteelProxyElement is not even documented in the API docs 😕
matthew_taylor
If you look at the SteelProxyElement in Revit 2023 RevitLookup when the SteelProxyElement is visible in the active view, the geometry will exist:
In the code itself, you may need to iterate through views (using each view in DB.Options with elem.Geometry(options)) to get a valid geometry element.
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
