GetMaximumWidthLimit error when creating new TextNotes
a-carpentier
a-carpentier
HI everyone,
When trying to programmatically add text notes with set width on my views, I sometimes get an error message stating:
The given width is not valid. A valid value must be within the range returned by static methods
GetMinimumWidthLimit and GetMaximumWidthLimit.
However I can't find any information about those two static methods.
So what width range is valid for a TextNote?
RPTHOMAS108
TextElement.GetMaximumAllowedWidth Method (Document, ElementId)
TextElement.GetMinimumAllowedWidth Method (Document, ElementId)
Inherited by TextNote
Code example given in RevitAPI.chm under:
TextNote.Create Method (Document, ElementId, XYZ, Double, String, TextNoteOptions)
a-carpentier
Thanks! I was searching for "GetMaximumWidthLimit" as specified in the error message and was not finding anything.
I think the error message should be modified to reflect the correct method names.
