Generate Direct Shape from Selected Wall Geometry
zrodgersTSSSU
zrodgersTSSSU
Hey Everyone, So dynamo allows you to get an elements geometry and then create a direct shape from the returned geometry. I am trying to do that same thing with API. I want to select a wall get its geometry and then create a direct shape that reflects all the openings in the wall.  I originally was going to copy and paste the wall in place then rotate it but revit doesnt alow you to rotate walls in the direction i want.
using (Transaction tx = new Transaction(doc))
                            tx.Start("Generate Tilt Wall");
                            foreach (ElementId elemId in selectedIds)
                                try
                                    Element elem = uidoc.Document.GetElement(elemId);
                                    if((BuiltInCategory)elem.Category.Id.IntegerValue == BuiltInCategory.OST_Walls)
                                        Options opts = new Options();
                                        GeometryElement geoEle = elem.get_Geometry(opts);
                                        XYZ newloc = new XYZ(0, 0, 0);
                                        //gets wall curve for rotation
                                        Curve eleCurve = (elem.Location as LocationCurve).Curve;
                                        XYZ startPoint = eleCurve.GetEndPoint(0);
                                        XYZ endPoint = eleCurve.GetEndPoint(1);
                                        //need to set this equal to something so i can modify it
                                        //ICollection<ElementId> newElemColl = ElementTransformUtils.CopyElement(doc, elemId, newloc);
                                        //ElementId newEleId = newElemColl.First();
                                        XYZ pt1 = new XYZ(0, 0, 0);
                                        XYZ pt2 = new XYZ(0, 0, 10);
                                        Line axis = Line.CreateBound(pt1, pt2);
                                        //ElementTransformUtils.RotateElement(doc, newEleId, axis, rotAngle);
                                        DirectShape ds = DirectShape.CreateElement(doc, new ElementId(BuiltInCategory.OST_Walls));
                                        ds.ApplicationId = "Application id";
                                        ds.ApplicationDataId = "Geometry object id";
                                        ds.SetShape(new GeometryObject[] { geoEle });
                                catch(Exception e) { throw e; }
                            tx.Commit();
error:
RPTHOMAS108
From DirectShapeType.SetShape  method noted in Revit API.chm:
pGeomArr
Type: System.Collections.Generic.IList<(Of <(<'GeometryObject>)>)>
Shape of this object expressed as a collection of GeometryObjects. These will be copied. Shape and Category should be consistent: geometry supplied as shape should be valid for the Category the type object is associated with. The supported types of GeometryObjects are: Solid, Mesh, GeometryInstance, Point, Curve and PolyLine.
i.e. GeometryElement (a collection of primitives) is not a supported GeometryObject.
You have to take the items out of it that are supported above and put them in your input list of GeometryObject.
zrodgersTSSSU
@RPTHOMAS108 thank you for the quick response. I got the solids and created the direct shape this way.
                                        opts.ComputeReferences = true;
                                        opts.IncludeNonVisibleObjects = true;
                                        foreach (GeometryObject geomObj in geoEle)
                                            Solid geomSolid = geomObj as Solid;
                                            if (null != geomSolid)
                                                ds.SetShape(new GeometryObject[] {geomSolid});
however... when i run it it gives me 4 extra solids.... seem to be faces. any idea how to only get the solid in the back?
RPTHOMAS108
You are including non-visible objects:
I would set that to false, have a look in RevitLookup to try an understand their meaning. Could be related to layers or references within the wall (not necessarily useful).
zrodgersTSSSU
Thank you that worked!!!
