Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
How to get LineWidth through LineWeight
7 REPLIES 7
Message 1 of 8
1073092683
633 Views, 7 Replies
How to get the actual width of a line through LineWeight
7 REPLIES 7
Message 2 of 8
jeremy_tammik
in reply to: 1073092683
Message 3 of 8
1073092683
in reply to: jeremy_tammik
Thank you for your answer, but what I really want to know is how to obtain the thickness of line width in RevitAPI
Message 4 of 8
jeremy_tammik
Aha. Well, that should be easy, assuming that you understand the Revit category and style settings hierarchy:
Message 5 of 8
1073092683
I already know the value of the red part, but I want to get the value of the blue part through the value of the red part,thank you!
Message 6 of 8
jeremy_tammik
Have you used RevitLookup to explore the contents of the Revit database in the appropriate locations? Basically, everything that can be accessed through the API can also be seen in RevitLookup, and that will also show you the path to retrieve it programmatically.
Message 7 of 8
Hi @1073092683 ,
Please take a look at this below forum post
https://forums.autodesk.com/t5/revit-api-forum/accessing-revit-lineweights/m-p/7978829#M30714
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Message 8 of 8
78 votes so far, that should give some weight to this wish:
https://forums.autodesk.com/t5/revit-ideas/access-line-weights-settings-from-dynamo-and-or-revit-api...
Please add your vote!
Rail Community
