We want to know the room numbers and geometry details which are present adjacent to walls. means if one wall is common to two rooms we want to know the room number and geometry details for that room, if any one room is present in linked document and wall is present in active document.
Kindly suggest the way out to find such a room details from linked room adjacent to wall in active document in Revit API.
Thank you.
Pravin
Dear Pravin,
Thank you for your query.
The Building Coder has discussed various approaches to achieve this in some depth.
Please refer to the topic groups on 2D Booleans, adjacent areas, spatial adjacency and thermal energy analysis model:
I hope this helps.
Please always perform your own search before submitting a new question here.
It will save time and effort for yourself and the rest of the world.
You will also learn more and become a better programmer.
Thank you!
Best regards,
Jeremy
Hi Jeremy,
Thanks for the response.
Is there any known issue for using GetBoundarySegments function for a room in a linked file?
The function is returning an array of 0 segments though the room bounding option is enabled. Plz advise.
Dear Mona,
I repeat the same message to you as well:
I searched the Internet for 'Revit GetBoundarySegments room linked' and immediately see a number of promising results:
https://duckduckgo.com/?q=revit+GetBoundarySegments+room+linked
Why don't you try that yourself as well?
Does it help to specify the linked model as room-bounding?
Apparently, there are (or were?) some problems in this area. They are discussed and several workarounds are suggested in the Revit API discussion thread on 'GetBoundarySegments With Linked Models':
https://forums.autodesk.com/t5/revit-api-forum/getboundarysegments-with-linked-models/td-p/7399357
Here is a description of the full algorithm with an accompanying Dynamo node implementation to achieve the task:
http://lubim.co/2019/05/10/room-boundaries-from-linked-documents/
This research took me a handful of minutes.
Surely it would have been more efficient for you to perform it yourself rather than to wait for my answer?
Good luck resolving your task and even more so practicing effective Internet searching in future cases!
Best regards,
Jeremy
Dear Mona,
I looked up the engineering database.
Unfortunately, the issue reported earlier (REVIT-120488 in here) is till open. The new change request ID is:
REVIT-120608: API | GetBoundarySegments omits edge from linked model
I have added your name to the the above ID. Feel free to provide me with the business case if you me to add to it. You can give through the private message (if you hover over my name profile, you should be able to send a private message. Or use DevHelp Online with the above ID.
In a mean time, you will need to workaround described here.
Sorry for the unfavorable result.
Dear Mona,
Please excuse the wording in my previous answer above.
I must have run into a couple of less professionally researched questions just prior to answering yours, and some sentiment overflowed into the wrong answer.
I really am doing my very best to help both you and the rest of the community.
That includes encouragement to others to research well before asking a question. Sometimes it is hard to tell.
I meant absolutely no offense to you or anybody else.
Thank you for your understanding.
Best regards,
Jeremy
