how to extract the geometry and the texts of the title block in a sheetview?
pmeigneux
Message 1 of 25
pmeigneux
I want to extract all that is visible and correctly placed in the attached image.
Replies (24)
Message 21 of 25
jeremytammik
Application > Documents > select the family definition document.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 22 of 25
pmeigneux
My code :
Ok, i found some TextNode, TextElement and ImageInstance. But my filters are not working.
Is there any documentation of filter ?
My code :
FilteredElementCollector collector = new FilteredElementCollector(DocFamily);
ICollection<Element> lines = collector.OfCategory(BuiltInCategory.OST_Lines).ToElements();
ICollection<Element> texts = collector.OfClass(typeof(TextNote)).ToElements();
Where is not error ?
Message 23 of 25
jeremytammik
Dear Pierre,
You really do need to learn to search the Internet.
In this case, for instance, you can just search for 'Revit API filtered element collector':
https://duckduckgo.com/?q=revit+api+filtered+element+collector
Please practice this for a bit before asking the next question.
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
Message 24 of 25
jeremytammik
The specific problem that you ran into was discussed in the note on reinitialising the filtered element collector:
https://thebuildingcoder.typepad.com/blog/2019/11/design-automation-api-stacks-collectors-and-links....
Jeremy Tammik
The Building Coder
Message 25 of 25
jeremy_tammik
I edited this conversation and preserved it for posterity on The Building Coder:
https://thebuildingcoder.typepad.com/blog/2021/01/sheet-view-xform-coords-img-export-and-title-block...
Thank you very much for your contributions!
