TextBoxData user input to set parameter values
AdvancedBIMSystems
AdvancedBIMSystems
I'm after a code example or links on how a TextBoxData value entered from a ribbon panel text box can be used to set a parameter value in a class.
Text box setup on ribbon panel works as follows :
TextBoxData modifyData = new TextBoxData("ModifyBox");
TextBox modify = modifyPanel.AddItem(modifyData) as TextBox;
modify.PromptText = "Enter a value in mm";
modify.ToolTip = "Test text box";
modify.EnterPressed += new EventHandler<TextBoxEnterPressedEventArgs>(ProcessText);
void ProcessText(object sender, TextBoxEnterPressedEventArgs args)
     TextBox textBox = sender as TextBox;
     string strText = textBox.Value as string;
     double doorwidth = Convert.ToDouble(strText);
Get & set "doorwidth" parameter in separate class as follows :
ElementId doorId = doorObj.ElementId;
Element door = doc.GetElement(doorId);
Parameter p01 = door.LookupParameter("Door Width");
using (Transaction tx = new Transaction(doc, "Set door width"))
    tx.Start();
    p01.Set(doorwidth);
    tx.Commit();
boostyourbim
What happens when you run your code? Is there an error? One possibility is that you should use an External Event, call the Raise() method in ProcessText, and put the transaction and Parameter.Set in the External Event's Execute method. If you want to pass the value when you raise the event, see https://forums.autodesk.com/t5/revit-api-forum/externalevent-raise-should-accept-parameters/td-p/550...
AdvancedBIMSystems
Thanks for taking the time to answer my question, much appreciated.
I ended up finding the solution here : https://forums.autodesk.com/t5/revit-api-forum/how-to-get-modeless-form-textbox-value/td-p/6008361
Cheers
