How to create duct with fittings .
MohammedHussam
MohammedHussam
public static Duct Create(
	Document document,
	ElementId ductTypeId,
	ElementId levelId,
	Connector startConnector,
	Connector endConnector
How to get the connectors , i am trying to create the duct from cad lines i am unable to get the connectors ,looking for someone who would help me to solve my issue .
Charles.Piro
you can create a duct with two points (XYZ) :
	Document document,
	ElementId systemTypeId,
	ElementId levelId,
	XYZ startPoint,
	XYZ endPoint
Next, for fittings, you need to create them with the connectors of the ducts. Here is a exemple of how to find the connectors and create an elbow :
//create the ducts
Duct newduct = Duct.Create(doc, mepSystemId, ductTypeId, levelId, pt1, pt2);
Duct newduct2 = Duct.Create(doc, mepSystemId, ductTypeId, levelId, pt2, pt3);
//find the connectors at point 2 :
Connector connectorElbow1 = null;
Connector connectorElbow2 = null;
foreach (Connector connectduct in newduct.ConnectorManager.Connectors)
      if (connectduct.Origin.IsAlmostEqualTo(pt2))
          connectorElbow1 = connectduct;
foreach (Connector connectduct in newduct2.ConnectorManager.Connectors)
             connectorElbow2 = connectduct;
//Create Elbow
FamilyInstance newElbow = doc.Create.NewElbowFitting(connectorElbow1, connectorElbow2);
PIRO Charles
Developer
PIRO CIE
Linkedin
MohammedHussam
Thank you @Charles.Piro  i have tried ur method but with cabletrays   and it worked but what if there is a 3 way Tee Fitting and 4 Way Cross Fitting , how to  handle for such conditions .
