Revit API: Support for N-Gons in TessellatedShapeBuilder?
vengateshhp2001
vengateshhp2001
I’m working with mesh data that includes n-gon faces (more than 4 vertices per face). Does TessellatedShapeBuilder in the Revit API support such geometry directly or else suggest any other way to support these scenario.
Thank you
essam-salah
hi @vengateshhp2001
@vengateshhp2001 wrote:
I’m working with mesh data that includes n-gon faces (more than 4 vertices per face). Does TessellatedShapeBuilder in the Revit API support such geometry directly or ..
I haven't used  TessellatedShapeBuilder but, but i'm sure it supports triangles, so basically you can use a triangulation algorithm (alot of them available on the internet in different prog languages),
