How to connect a horizontal cable tray with a vertical cable tray by Revit API
Message 1 of 13
In following picture, there is a horizontal cable tray, and I want to draw a vertical cable tray starting from the middle point of the horizontal cable tray. when I use Revit ribbon drawing function, the horizontal cable tray and the vertical cable connect very well. But I am sure the horizontal cable tray is not split by the vertical cable tray, and an extra connector is added to the horizontal cable tray on the middle point, and a connection is made between this added connector from the horizontal cable tray and one end connector from the vertical cable tray. And no tee fitting is added.
Revit didn't create a tee fitting, but the horizontal cable tray and the vertical cable tray do connect well even there is no tee fitting. I don't know why.
When I use NewTeeFitting method to do it, it return null directly. I have also tried NewTakeoffFitting API, but it gave an exception and said: you can't use NewTakeoffFitting API for cable tray connection.
See issue in Revit API forum:
https://forums.autodesk.com/t5/revit-api-forum/how-to-connect-a-horizontal-cable-tray-with-a-vertica...
How can I do that by Revit API?
Best Regards,
 Zhangzg
Replies (12)
Message 2 of 13
jeremytammik
You say you use the Revit ribbon drawing function.
What is the exact result of that?
What elements are placed and what connections generated?
Do you want to achieve the exact same result programmatically?
Cheers,
Jeremy.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 3 of 13
Hi
Best Regards,
Zhangzg
Message 4 of 13
jeremytammik
@aignatovich showed you how to connect a horizontal cable tray with a vertical on in the other thread of yours:
Why do you not accept his solution?
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 5 of 13
Hi
I have read @aignatovich 's reply. His solution is only used for two horizontal cable trays but not a vertical and a horizontal cable tray. I have explained this in my reply to him.
But I want to know how to connect a horizontal cable tray with a vertical cable tray by API.
Best Regards,
Zhangzg
Message 6 of 13
jeremytammik
Oh, I misunderstood his description.
I am checking now with the development team for a solution.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 7 of 13
jeremytammik
The development team replied, and the news is not very promising, I'm afraid:
First, one person said: I believe the work around is similar to plumbing fixtures in that you need to:
  • Set the location of the existing element requiring a split to a new line from the old start point to the point on a T connector at the intersection point
  • Create a new element from the T connector to the old elements endpoint.
  • Create the vertical from the T connector to the next desired termination point.
There are several Python based examples of this for pipes on the Dynamo forums.
A second person added: Just double checked with team, for cable tray in this case, it is connected with another cable tray through curve connector. Currently there is no API to create a curve connector directly like this.
Please raise a wish list item for this in the Revit Idea Station.
Thank you!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 8 of 13
Hi
Thank you so much for your careful reply.
I agree with the second person: for cable tray in this case, it is connected with another cable tray through a curve connector, but currently there is no API to create a curve connector directly like this. In fact, in this case a curve connector is added at a middle point of the horizontal cable tray.
I will post a item in Revit Idea Station.
Thank you again, and I often read your blog: https://thebuildingcoder.typepad.com/blog/about-the-author.html, It is very helpful.
Best Regards,
Zhigang Zhang
Message 9 of 13
jeremytammik
Dear Zhigang Zhang,
Will the following connection satisfy your requirement?
If so, API support is available, since this solution uses a normal fitting rather than a curve connection.
If you don't want the fitting, we may need API support for the curve connector first.
I hope this helps.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 10 of 13
Hi
Thank you so much for your reply.
Yes, the connection with a normal tee fitting can satisfy my requirement, and it looks very well.
I know in some cable tray types there are several proper tee fittings for T-connection, and then no API support is needed. But in some other cable tray types there are no proper tee fittings for T-connection, so we have to use a curve connection.
Best Regards,
Zhigang Zhang
Message 11 of 13
jeremytammik
I am confused by the parallel conversations in these two threads:
It would be nice if they could be summarised and unified...
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 12 of 13
jeremytammik
Did you ever submit that wish to the Revit Idea Station?
Can you provide a link to that, please?
Thank you!
Jeremy Tammik
The Building Coder
Message 13 of 13
Hi
Thanks for your reply!
I have submitted a wish to the Revit Idea Station, and the link is as follow:
https://forums.autodesk.com/t5/revit-ideas/provide-api-to-create-a-curve-connector/idi-p/8774958
Best Regards,
Zhangzg
