Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
How to collect all elements of given top category?
4 REPLIES 4
Act-3D
4757 Views, 4 Replies
I can collect all elements of given category Id:
ICollection<ElementId> ids = new FilteredElementCollector(doc).OfCategoryId(categoryId).ToElementIds();
But how to collect all elements of given top category?
For example I want to collect all elements of top category "Windows" which means all elements where category is Windows->Glass, Windows->Frame/Mullion etc.
4 REPLIES 4
JimJia
in reply to: Act-3D
Please accept our sincerer apology for the delay! We had a backlog in the queue.
In your case, we suggest you using the enum class Autodesk.Revit.DB.BuiltInCategory.
You can try following code:
ElementFilter windowCategoryFilter = new ElementCategoryFilter(BuiltInCategory.OST_Windows);
ICollection<ElementId> ids = new FilteredElementCollector(doc).WherePasses(windowCategoryFilter).ToElementIds();
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
Act-3D
in reply to: JimJia
Hi Jim,
Thank you for your answer.
And what about elements inside a family?
For example, in example Revit project rac_basic_sample_project.rvt there is a Curtain wall (see screenchot).
It is category: Wall. How to get all elements ids inside this?
matthew_taylor
in reply to: Act-3D
Hi @Act-3D,
The old-fashioned way to do this would be to delete the curtain wall, see which elementIds were deleted, and then rollback the transaction afterwards. (As described for another element type here: http://thebuildingcoder.typepad.com/blog/2010/11/access-to-sketch-and-sketch-plane.html
Now, you can probably get all you need by using the properties of Wall.CurtainGrid.
Not exactly a filteredElementCollector, but I'm not sure that approach is workable in this instance.
Cheers,
-Matt
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
Act-3D
in reply to: matthew_taylor
Thank you Matt.
Forma Design Contest
Rail Community
