How to close the Editing Request Placed window programmatically
talalaevd
talalaevd
I implemented the error handling as follows
public class MyWorksetElementPreprocessor : IFailuresPreprocessor
            public FailureProcessingResult PreprocessFailures(FailuresAccessor failuresAccessor)
                IList<FailureMessageAccessor> failList = new List<FailureMessageAccessor>();
                failList = failuresAccessor.GetFailureMessages();
                foreach (FailureMessageAccessor failure in failList)
                    FailureDefinitionId failID = failure.GetFailureDefinitionId();
                    if (failID == BuiltInFailures.EditingFailures.OwnedByOther)
                        failuresAccessor.ResolveFailure(failure);
                        return FailureProcessingResult.ProceedWithRollBack;
                return FailureProcessingResult.Continue;
private static Transaction MakeTransaction(Document doc, string name, bool useFailureHandlingOpts)
            Transaction t = new Transaction(doc, name);
            if (useFailureHandlingOpts)
                FailureHandlingOptions opts = t.GetFailureHandlingOptions();
                opts.SetClearAfterRollback(true);
                opts.SetFailuresPreprocessor(new MyWorksetElementPreprocessor());
                t.SetFailureHandlingOptions(opts);
            return t;
public bool UpdateProjectEdit(Document _doc, TreeView _treeview, string _name)
            bool result = false;
            TreeNode elms = _treeview.SelectedNode;
            Element elm_rename = (Element)elms.Tag;
            TransactionStatus t_status;
            using (Transaction t = MakeTransaction(_doc, "Rename element " + elm_rename.Name, true))
                t.Start();
                elm_rename.Name = _name;
                t_status = t.Commit();
            if (t_status != TransactionStatus.RolledBack)
                result = true;
            return result;
But when processing a borrowed item error, this window appears2017-06-27_14-26-22.jpg
I do not know yet how to close this window automatically. Does anyone have any advice?
Дмитрий Талалаев
Эксперт BIM2B
Блог
Facebook | Twitter | LinkedIn
talalaevd
I tried to use EventHandler <DialogBoxShowingEventArgs> but the specified window is not intercepted in any way. In the log there is an entry about the event Jrn.PushButton "Modal, Hosted editing request, Dialog_Revit_CheckEditabilityGrants", "Close, IDOK".
What can Dialog_Revit_CheckEditabilityGrants mean and where can I use it?
Дмитрий Талалаев
Эксперт BIM2B
Блог
jeremytammik
Dear Дмитрий,
Thank you for your query.
All that I can say about handling dialogues and failures is covered by The Building Coder topic group 5.32:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.32
If all else fails, you can always use the Windows API to simulate mouse clicks and all other required user input:
http://thebuildingcoder.typepad.com/blog/2009/10/dismiss-dialogue-using-windows-api.html
In this case, with one single button to click, that should be fairly easy.
You can also submit a request to the Revit Idea Station for future versions of the Revit API to support this action directly.
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
talalaevd
Thanks Jeremy.
I'll have to use the Windows API to simulate a user clicking a button.
Дмитрий Талалаев
Эксперт BIM2B
Блог
