API for Cycle Section Head / Tail ???
I'm new into Revit API.
There is any method to access the function Cycle Section Head / Tail from Revit?
I was thinking is something like at datum elements, but are different classes. For levels and grids is possible to hide quickly the end bubble. But for the sections should be other method.
Any suggestion? Thanks.
jeremytammik
Probably not possible right now, as you can see from the following discussion, which also suggests a workaround:
https://forum.dynamobim.com/t/dynamo-revit-api-hide-section-head-tail-in-view-by-instance/12684/6
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
I was hoping to found something.. so I'll take the alternative method.
Thanks for confirmation!
@jeremytammik Is there still no solution for this problem, I am trying to do the same.
I created a view section using Revit API in c# and the created section lacks the section tail and can't get the parameter related to it.
jeremy_tammik
Can you achieve what you need manually through the end user interface? If so, please do so, and analyse the exact changes generated by the modification in the Revit database on the elements, their parameters and properties using RevitLookup and other API methods. Maybe that will provide a hint on how to achieve the same programmatically as well.
