Get Angle between two points
MarkSanchezSPEC
MarkSanchezSPEC
With the Plant 3D or AutoCAD .NET API, I can "calculate a vector between two points and determines the angle from the X-axis" like this:
Plant 3D
Dim pt1 As New Point2d(2142.371247, -2066.73581)
Dim pt2 As New Point2d(2142.371247, -1989.581039)
Dim angle As Double = pt1.GetVectorTo(pt2).Angle	'RETURNS 1.5707963267948966 IN RADIANS, WHICH IS 90-DEGREES
I'm not able to do likewise with the Revit API however. I've tried the "AngleOnPlaneTo" and "AngleTo" but do not get the expected results as above:
Dim pt1 As New XYZ(2142.371247, -2066.73581)
Dim pt2 As New XYZ(2142.371247, -1989.581039)
Dim angle2 As Double = pt1.AngleOnPlaneTo(pt2, New XYZ(0, 0, 1))	'RETURNS 0.01899334843737778
Dim angle3 As Double = pt1.AngleTo(pt2)	'RETURNS 0.018159197737853211
 Any suggestions?
jeremytammik
Dear Mark,
Thank you for your query.
The AngleTo method documentation says that it "returns the angle between this vector and the specified vector":
http://www.revitapidocs.com/2017/4251dd2b-1b48-8b2e-7159-02333cdf39e6.htm
The input you define above is given as points.
You need to convert your point input to vectors, e.g.:
  XYZ pt1 = New XYZ(2142.371247, -2066.73581, 0)
  XYZ pt2 = New XYZ(2142.371247, -1989.581039, 0)
  XYZ vector_from_pt1_to_pt2 = pts - pt1
  double angle = vector_from_pt1_to_pt2.AngleTo( XYZ.BasisX )
By the way, if you are just starting to explore the Revit API, I would strongly suggest working through the getting started material first:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#2
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
MarkSanchezSPEC
Thank you sir.
