Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
How to change host category of rebar?
3 REPLIES 3
hai_nn
249 Views, 3 Replies
Hi everyone,
I have a rebar with the host category - Structural Framing, how can I change the host to another category, for example Structural Column?
3 REPLIES 3
jeremy_tammik
in reply to: hai_nn
This depends on where the rebar is located. Look at the help topic on Rebar Instance Properties:
https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-A1D6AB67-B60F-4A15-913C-FD534C94D491
Host Category Specifies the current host associated with the reinforcement elements: Structural Column, Structural Framing, Structural Foundation, Wall, Floor, or Part.
hai_nn
in reply to: jeremy_tammik
My goal is to change the host category of an already created rebar.
iankybes
in reply to: hai_nn
Hi, did you figure this out, I have a similar problem with my top bars in beams hosting to floors instead of structural framing. This also affects how I propagate the rebar
Rail Community
