I am using Revit 2021 and inserted a .dwg I made on Inventor 2019. I need it as a size reference to make topography but for some reason it inserts at the wrong orientaion. I tried exporting it as a different file type and got the same results. I tried redefining the front before exporting and it still inserted the file at the same orientation.
I am new to Revit and finding it quite confusing and unobvious and silly, but tutorials seem to be on how to make floorplans or topography so they can't help me with this. Other forums with the same question are older and have solutions requiring buttons I simply cannot find on 2021. Should I insert the CAD part into a Model or Family, and which Family should I be using, and how can I rotate the object or redefine its orientation? Should I use an earlier version or a different Autodesk software altogether? I want to make topography and insert lots of CAD models in it.
I'm going to vent a bit for a second so forgive me, but SOMETIMES I FEEL LIKE THE ONLY SANE PERSON ON THIS PLANET LIKE OMG WHY CAN'T YOU DO OBVIOUSE THINGS AND IF THERE IS A GOOD REASON GONNA TELL US WHAT IT IS AND THE HELP SECTION FOR ROTATING ELEMENTS JUST SAYS YOU CAN ONLY ROTATE HORIZONTALLY BUT DOESN'T LINK TO ALTERNATIVES FOR VERTICLE ROTATION LIKE OMG
Thank you.
