Get view that generic annotation resides on
seanUFNGF
seanUFNGF
I'm very new to the Revit API and C#, so all the usual noob disclaimers are relevant here.  I'll describe what I've got working so far, and then describe where I'm having difficulty.
I have a generic annotation that includes a label into which you can type whatever you'd like.  This content is kept as the value for a parameter I've created called "Note Content".  I've successfully implemented a Revit ribbon button that returns all annotations with the "Note Content" parameter and the associated value and lists these notes in a WPF window.
And now the "I'm stumped" part...
I'd like to include the location (view/sheet) in the set where the annotation resides.  I'm using the OwnerViewId property to do this, and when implemented in code, it just returns an integer.  However, when I snoop the annotation element using Revit Lookup, I see the OwnerViewId property, but it lists more than just an integer value.  It actually lists 3 values.  For example, the OwnerViewId property for one of these annotations has a value of '<ViewPlan  Level 1  356>'  I've only been able to get the '356' part of that to return, but I can see what I want right there!  I want the 'Level 1' part.  And when I click on the OwnerViewId property in the Revit Lookup window to go deeper, it opens another window, and there's a property called Name that has a value of 'Level 1'.  So again, I can see what I want to return.  But I can't for the life of me figure out how to get to it and pull it out.  Anyone have any insight?
(Revit 2019.2, Windows 10 Pro)
architect.bim
Hello!
OwnerViewId property returns ElementId object of View/Sheet on which your annotation element is placed. If you need the actual name or number of that view/sheet you should first get view/sheet object. It can be done with GetElement method of Document class. After you get view/sheet you can retrieve necessary properties from it. I show you example in Python:
>>> view = doc.GetElement(g_annotation.OwnerViewId)
>>> view
<Autodesk.Revit.DB.ViewSheet object at 0x000000000000002E [Autodesk.Revit.DB.ViewSheet]>
>>> view.Name
'Floor Plan'
>>> view.SheetNumber
'A1'
>>> view.ViewType
Autodesk.Revit.DB.ViewType.DrawingSheet
Maxim Stepannikov | Architect, BIM Manager, Instructor
seanUFNGF
Thanks so much, Maxim!  That gave me what I needed!
