06:15 AM
Hi I've trying to change the properties "Phase filter" and "Phase" by code, when I'm on Active View with no results
I read these posts and others ones:
http://thebuildingcoder.typepad.com/blog/2009/03/create-room-on-level-in-phase.html
https://forums.autodesk.com/t5/revit-api-forum/change-phase-of-a-view/m-p/5223335
http://thebuildingcoder.typepad.com/blog/2014/08/setting-the-phase-of-a-view.html
I attached an image with the properties what I want to change programmatically.
I have this code:
using (ViewCreatorForm viewCreator = new ViewCreatorForm(commandData)) { if (viewCreator.ShowDialog() == System.Windows.Forms.DialogResult.OK) { List<PhaseFilter> _phFilters = new FilteredElementCollector(doc).OfClass(typeof(PhaseFilter)).Cast<PhaseFilter>().ToList(); PhaseFilter filter = _phFilters.Find(p => p.Name.ToUpper() == "Show current phase only".ToUpper()); using (Transaction transaction = new Transaction(doc, "Duplicate Views")) { transaction.Start(); List<View> views = tools.GetAllViews(doc); List<string> newViewName = new List<string>(); string temp = string.Empty; views = views.FindAll(p => p.ViewType == ViewType.ThreeD || p.ViewType == ViewType.FloorPlan); foreach (View view in views) { temp = string.Empty; try { switch (view.ViewType) { case ViewType.ThreeD: case ViewType.FloorPlan: foreach (string phaseName in viewCreator.CheckedPhases) { temp = view.ViewName; if (temp.Contains(phaseName)) { newViewName.Add(temp); } else { newViewName.Add(string.Format("{0} {1}", temp, phaseName)); } view.ViewName = newViewName.Last(); view.Duplicate(ViewDuplicateOption.WithDetailing); view.ViewName = temp; /////////// I'd like to add your help in here /////////// } break; } } catch (Exception) { } } transaction.Commit(); } } }
Can you help?
Regards!
