How to change by code "phase" and "phase filter" in phasing from properties
Hi I've trying to change the properties "Phase filter" and "Phase" by code, when I'm on Active View with no results
I read these posts and others ones:
http://thebuildingcoder.typepad.com/blog/2009/03/create-room-on-level-in-phase.html
https://forums.autodesk.com/t5/revit-api-forum/change-phase-of-a-view/m-p/5223335
http://thebuildingcoder.typepad.com/blog/2014/08/setting-the-phase-of-a-view.html
I attached an image with the properties what I want to changeforos.PNG programmatically.
I have this code:
using (ViewCreatorForm viewCreator = new ViewCreatorForm(commandData)) {
                        if (viewCreator.ShowDialog() == System.Windows.Forms.DialogResult.OK) {
                            List<PhaseFilter> _phFilters = new FilteredElementCollector(doc).OfClass(typeof(PhaseFilter)).Cast<PhaseFilter>().ToList();
                            PhaseFilter filter = _phFilters.Find(p => p.Name.ToUpper() == "Show current phase only".ToUpper());
                            using (Transaction transaction = new Transaction(doc, "Duplicate Views"))
                                transaction.Start();
                                List<View> views = tools.GetAllViews(doc);
                                List<string> newViewName = new List<string>();
                                string temp = string.Empty;
                                views = views.FindAll(p => p.ViewType == ViewType.ThreeD || p.ViewType == ViewType.FloorPlan);
                                foreach (View view in views)
                                    try
                                        switch (view.ViewType)
                                            case ViewType.ThreeD:
                                            case ViewType.FloorPlan:
                                                foreach (string phaseName in viewCreator.CheckedPhases)
                                                    temp = view.ViewName;
                                                    if (temp.Contains(phaseName))
                                                        newViewName.Add(temp);
                                                    else
                                                        newViewName.Add(string.Format("{0} {1}", temp, phaseName));
                                                    view.ViewName = newViewName.Last();
                                                    view.Duplicate(ViewDuplicateOption.WithDetailing);
                                                    view.ViewName = temp;
/////////// I'd like to add your help in here ///////////
                                                break;
                                    catch (Exception)
                                transaction.Commit();
Can you help?
Regards!
RPTHOMAS108
Changing these properties should be the same as changing any built-in parameter.
If they are ReadOnly then likely a Template has been applied. templates should also be excluded from your loop (check View.IsTemplate).
Information gathered via lookup tool (Revit 2019):
Phase: BuiltInParameter.VIEW_PHASE
-1012102, StorageType: ElementID
Phase Filter: BuiltInParameter.VIEW_PHASE_FILTER
-1012103, StorageType: ElementID
The storage type is ElementID therefore this implies you need to filter for the named Phase and PhaseFilter objects you want in order to get the ID to set.
Tnx for answer RPTHOMAS108, but I'm rookie in revit, do you have some example?
Regards!
studio-a-int
You will need to get the phases in your active document:
PHASES = doc.Phases
iterate through, to select the Phase you want:
EX_PHASE = [i for i in PHASES if i.Name == '01 - Existing'][0] # This is the Existing Phase
then select the view, you want to change the Phase (make sure you do not have a ViewTemplate applied to that view).
MY_VIEW = [i for i in FilteredElementCollector(doc).OfClass(View).ToElements() if i.Name == 'Level 1']
after that set the phase inside of a transaction:
t = Transaction(doc,"CHANGE VIEW PHASE")
t.Start()
for i in MY_VIEW:
    i.get_Parameter(BuiltInParameter.VIEW_PHASE).Set(EX_PHASE.Id)
doc.Regenerate()
t.Commit()
This code is Python, inside Dynamo.
Hi studio-a-int, tnx for asnwer, i tryed your advice, but cannot make it work
this is the code:
views = tools.GetAllViews(doc); PhaseArray Phases = doc.Phases; //It have all phases
string notChanged = string.Empty;
foreach (string viewName in newViewName) { var viewsTemp = views.FindAll(p => p.ViewName.Contains(viewName)); if (viewsTemp.Count == 1) { try { viewsTemp.First().get_Parameter(BuiltInParameter.VIEW_PHASE).Set(4); //arbitrary hardcoded an existing ID } catch (Exception) { notChanged += viewsTemp.First().ViewName+","; }
} if(!string.IsNullOrEmpty(notChanged)) TaskDialog.Show("Error changing phases", notChanged);
doc.Regenerate();
but I can't see changed the propierty, do you have any idea what am I missing?
studio-a-int
VIEW_PHASE is an ElementId  storage type.
You are using an integer in your code.
Change that from "4" as you have it, to Phase-you-want-to-chage.Id
IE Phase-you-want-to-chage = '01 - Existing' or 'Project Completion'
In that round parenthesis, you should have an ElementId, not the integer "4" as you have it right now.
Look @ Phase Members and Phase Properties in Revit API.
Hi, tnx, I was about to post that xD, and yes, that was my mistake, i handled ids like 0 to n, but it have internals id's, so I need Element.Id necessary,
this is the working code:
List<PhaseFilter> _phFilters1 = new FilteredElementCollector(doc).OfClass(typeof(PhaseFilter)).Cast<PhaseFilter>().ToList();
PhaseFilter filter1 = _phFilters.Find(p => p.Name.ToUpper() == "MY FILTER PHASE".ToUpper());
Phase phaseFound=null;
foreach (Phase phase in doc.Phases)
if (phase.Name=="MY PHASE") {
phaseFound = phase;
foreach (string viewName in newViewName) { var viewsTemp = views.FindAll(p => p.ViewName.Contains(viewName)); if (viewsTemp.Count == 1) { try { if(phaseFound!=null) viewsTemp.First().get_Parameter(BuiltInParameter.VIEW_PHASE).Set(phaseFound.Id); viewsTemp.First().get_Parameter(BuiltInParameter.VIEW_PHASE_FILTER).Set(filter1.Id); } catch (Exception) { notChanged += viewsTemp.First().ViewName+","; }
Tnx to everybody for the help!
