Change Phase Filter and Phase from Phasing in Properties
Message 1 of 1
Hi I've trying to change the properties "Phase filter" and "Phase" by code, when I'm on Active View with no results
I read these posts and others ones:
http://thebuildingcoder.typepad.com/blog/2009/03/create-room-on-level-in-phase.html
https://forums.autodesk.com/t5/revit-api-forum/change-phase-of-a-view/m-p/5223335
http://thebuildingcoder.typepad.com/blog/2014/08/setting-the-phase-of-a-view.html
I attached an image with the properties what I want to changeforos.PNG programmatically.
I have this code:
using (ViewCreatorForm viewCreator = new ViewCreatorForm(commandData)) {
                        if (viewCreator.ShowDialog() == System.Windows.Forms.DialogResult.OK) {
                            List<PhaseFilter> _phFilters = new FilteredElementCollector(doc).OfClass(typeof(PhaseFilter)).Cast<PhaseFilter>().ToList();
                            PhaseFilter filter = _phFilters.Find(p => p.Name.ToUpper() == "Show current phase only".ToUpper());
                            using (Transaction transaction = new Transaction(doc, "Duplicate Views"))
                                transaction.Start();
                                List<View> views = tools.GetAllViews(doc);
                                List<string> newViewName = new List<string>();
                                string temp = string.Empty;
                                views = views.FindAll(p => p.ViewType == ViewType.ThreeD || p.ViewType == ViewType.FloorPlan);
                                foreach (View view in views)
                                    try
                                        switch (view.ViewType)
                                            case ViewType.ThreeD:
                                            case ViewType.FloorPlan:
                                                foreach (string phaseName in viewCreator.CheckedPhases)
                                                    temp = view.ViewName;
                                                    if (temp.Contains(phaseName))
                                                        newViewName.Add(temp);
                                                    else
                                                        newViewName.Add(string.Format("{0} {1}", temp, phaseName));
                                                    view.ViewName = newViewName.Last();
                                                    view.Duplicate(ViewDuplicateOption.WithDetailing);
                                                    view.ViewName = temp;
/////////// I'd like to add your help in here ///////////
                                                break;
                                    catch (Exception)
                                transaction.Commit();
Can you help?
Regards!
Replies (0)
