How to add a type that can be used in the panel schedules template?
So I am trying to add an area (sq ft) parameter to the panel schedules, so Revit can calculate the wattage. In this case, I want to multiply the area by 3 and get a VA load calculation. I tried many things here:
1.) I tried to add a family/shared parameter in the panel itself by clicking on the panel -> edit family -> family types -> adding a new parameter -> and then trying both family/shared parameters. But the thing here is, when you try and add a family parameter, it won't appear in schedules or tags. When I try and add a shared parameter, there seems to be a fixed list of parameters that can't be edited, added, or deleted. Even if I do add a shared parameter, it won't show up in the panel schedules.
2.) I tried making a new type of outlet that is also an "area" outlet. Because at least with this, in the panel schedules template that I made, the stuff will show up. But it only shows "connected, connected current, demand factor, estimated demand, estimated demand current" — none of which can be edited or found by me.
So if you can help me try and find a way to make the panel schedules do 3*area (where I can just put in the number myself — Revit doesn't need to do it, I can), that will be great.
