Como hacer para crear una rejilla con una cantidad X.
Como hacer a través de API una rejilla en Revit como la que muestro como ejemplo en la imagen.
jeremytammik
Dear Enzo,
Thank you for your query.
You may possibly have better chances of getting a good answer asking in English.
You ask: how can I programmatically create a grid?
You can find many answers on the Internet by searching for 'revit api create grid':
https://duckduckgo.com/?q=revit+api+create+grid
The very first one that comes up does indeed address your question:
http://forums.augi.com/showthread.php?100405-Draw-Grid-Lines-using-Revit-API-in-C
Apparently, you create the Grid by feeding it with a geometric line or arc:
  Line line = revitApp.Create.NewLineBound(sPoint, ePoint);
  Grid g = revitApp.ActiveDocument.Create.NewGrid(line);
The NewGrid method is now obsolete, and replaced by the static Grid.Create method:
http://www.revitapidocs.com/2018/00ae8045-b65e-40b1-c162-ef5048fcf9f9.htm
That lead me to search the Internet again, this time for 'revit api grid.create':
https://duckduckgo.com/?q=revit+api+grid.create
That led to the Autodesk knowledge network article on grids:
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2016/ENU/Revit-API/files/GUID-...
As always when researching a Revit API task, it will help if you create the desired situation manually and explore that in depth, e.g., using RevitLookup, or other, more intimate, database exploration methods:
http://thebuildingcoder.typepad.com/blog/2017/01/virtues-of-reproduction-research-mep-settings-ontol...
http://thebuildingcoder.typepad.com/blog/2013/11/intimate-revit-database-exploration-with-the-python...
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
