InvalidOperationException: Wall set_ElementsAtJoin
Message 1 of 9
Hello everyone,
Choose the No.1 wall:
ElementArray arr = (wall1.Location as LocationCurve).get_ElementsAtJoin(0);
arr values :[wall1,wall2]
__________________________________________
I want to add the No.3 wall to the ElementArray .
elementArray = [wall1,wall2,wall3]
(wall1.Location as LocationCurve).set_ElementsAtJoin(0, elementArray);
The error information is as follows:
Autodesk.Revit.Exceptions.InvalidOperationException
at Autodesk.Revit.DB.LocationCurve.set_ElementsAtJoinInternal(Int32 end, List`1 elements)
at Autodesk.Revit.DB.LocationCurve.set_ElementsAtJoin(Int32 end, ElementArray elements)
at Revit.numWall.Execute(ExternalCommandData commandData, String& message, ElementSet elements)
Replies (8)
Message 2 of 9
aignatovich
Hi!
There is a remark in description of LocationCurve.ElementsAtJoin Property in Revit SDK:
The list of elements is expected to be a permutation of the elements already in the join at the end. It is expected that no new elements will be introduced, and existing ones will not be removed.
If you want to join walls, you should allow joins at specific wall end and Revit will join walls to you automatically. Look at WallUtils static class. It has AllowWallJoinAtEnd, DisallowWallJoinAtEnd and IsWallJoinAllowedAtEnd methods.
Message 3 of 9
Hi, this method has been used.
WallUtils.AllowWallJoinAtEnd(wall1, 0);
WallUtils.AllowWallJoinAtEnd(wall1, 1);
WallUtils.AllowWallJoinAtEnd(wall2, 0);
WallUtils.AllowWallJoinAtEnd(wall2, 1);
WallUtils.AllowWallJoinAtEnd(wall3, 0);
WallUtils.AllowWallJoinAtEnd(wall3, 1);
Message 4 of 9
aignatovich
Can you join all 3 walls via UI? May be they are already joined? Or may be there is something, that prevents Revit to join them?
Message 5 of 9
yes!
may be "set_ElementsAtJoin" is not allowed to add elements.
Attachments are model files.
Thank you very much for your help!
Message 6 of 9
aignatovich
Yes, you can't add or remove joins via set_ElementsAtJoin.
I explored a bit your model. These walls are already joined:
Message 7 of 9
Looking at the  already joined from UI.
But using "wall1.get_ElementsAtJoin(0)" method, the result do not contain  wall3.
Wall wall1 = doc.GetElement(uiDoc.Selection.PickObject(Autodesk.Revit.UI.Selection.ObjectType.Element).ElementId) as Wall;
Test by the following methods:
var elementArray = (wall.Location as LocationCurve).get_ElementsAtJoin(0);
foreach(var element in elementArray )
   elementIds.Add(element.Id);
uiDoc.Selection.SetElementIds(elementIds);
Message 8 of 9
aignatovich
A bit strange thing, but it works. Just disallow joins and then allow it again. If you create these walls programmatically, I think you should regenerate the document before performing this trick.
This is Iron Python shell code:
# you should select a wall before running this
tx = Transaction(doc, "test")
tx.Start()
WallUtils.DisallowWallJoinAtEnd(selection[0], 0)
WallUtils.AllowWallJoinAtEnd(selection[0], 0)
tx.Commit()
Message 9 of 9
Thank you very much. It's OK.
It's so strange!!!
