How Stop or Cancel revit closing
Message 1 of 11
HI everyone
I developing my addin using C# 2012, I need my application stop the closure revit. I have a routine that is executed when a button of RibbonPanel press and public Boolean variable is assigned true. Whether revit closing the variable = false, revit not close. I want to force the user to press the button before closing revit. That event or method I can use?. i try with DocumentClosing but this method run only if a document closing and not when revit closing .
thanks!
Replies (10)
Message 2 of 11
arnostlobel
It is not possible to prevent the end-user from closing Revit, not from via the Revit API anyway. I suppose you could use the Windows System API to prevent Revit closing, by stealing windows messages, for example. However, that may lead to unexpected behavior, sometime.
Arnošt Löbel
Arnošt Löbel
Message 3 of 11
jeremytammik
Your add-in OnShutdown method should be called when and only when Revit is closing. That will at least give you a chance to display the message to the user and "force her to press a button", if you really think that is a good idea, even if it does not enable you to prevent Revit from closing.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 4 of 11
Moustafa_K
You can try adding an Event Handler to stop Revit from Closing  you can add that on startup
  public Result OnStartup(UIControlledApplication Application)
          ///some code
                Application.ApplicationClosing += Application_ApplicationClosing;
                return Result.Succeeded;
        private void Application_ApplicationClosing(object sender, Autodesk.Revit.UI.Events.ApplicationClosingEventArgs e)
         if(yourvariable== false)   e.Cancel();
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
Message 5 of 11
jeremytammik
Good suggestion!
You would have to check fiurst whether the application closing event is cancellable:
ApplicationClosingEventArgs is derived from RevitAPIEventArgs, and the RevitAPIEventArgs.Cancellable property indicates whether an event may be cancelled by an event delegate.
Can you confirm that?
Thank you!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 6 of 11
arnostlobel
ApplicationClosing events aren't cancellable. It is by design.
If you try calling Cancel() on an event that is not cancellable, Revit throws an exception.
This is basically what I mean by stating that Revit cannot be prevented from shutting down via the Revit API.
Arnošt Löbel
Message 7 of 11
jeremytammik
... as expected ...
Sorry Mostafa90, a shame about your good idea, but no cigar this time  🙂
Jeremy Tammik
The Building Coder
Message 8 of 11
Moustafa_K
Yeaah... 🙂 tried to Help any way.
Moustafa Khalil
Message 9 of 11
Thanks guys!!!
Message 10 of 11
Hello, I have the same problem now. Is there a solution to this topic?
Message 11 of 11
jeremytammik
The Revit API will not help you with this, as explained above.
Therefore, you will have to treat this as a generic .NET and Windows question, on how to prevent an arbitrary application from closing.
For instance, you can search for something like 'prevent windows application from closing .net':
https://duckduckgo.com/?q=prevent+windows+application+from+closing+.net
This thread suggest some valid solutions:
https://serverfault.com/questions/709765/prevent-users-from-closing-certain-application
Jeremy Tammik
The Building Coder
