How do I go from a FamilyParameter to a Parameter on a FamilyInstance?
David_Robison
985 次查看
1 条回复
1 条消息(共 2 条)
David_Robison
Short version:
I have a FamilyParameter.IsInstance is set to True on it.
I have a FamilyInstance.
How do I get the Parameter from the FamilyInstance that corresponds to the FamilyParameter?
Long version:
I'm trying to get the load on an electrical device. I have the FamilyInstance in the project.
The load is set in the connector. To get the load from the connector, I have to go the family document. See this other forum post for background.
On the connector, I get the load parameter.
But! The has set the built-in load parameter to depend on a family parameter that he has created. It is an instance parameter so that in the project he can set the load for each device. I need to find this load.
I Use GetAssociatedFamilyParameter to get the FamilyParameter that is being used.
I check FamilyParameter.IsInstance and see that it is an instance parameter.
Now I need to go back to the instance and find the parameter to get the value.
I can't get the parameter using the definition (returns null) or GUID (not a shared parameter so doesn't exist).
In the Definition the names match but not the Id. I could iterate over all the parameters and find it that way, but if there are two parameters with the same name, I'm not sure how to make sure I found the right one. And that doesn't "feel" like the right way to get the parameter, but it could be my intuition is off on this.
0 个赞
已接受的解答 (1)
986 次查看
1 条回复
回复 (1)
2 条消息(共 2 条)
jeremytammik
已接受的解答
Dear David,
I am sorry to say that you are right.
The only way I know to identify a non-shared family parameter on the instance is by using its display name.
I recommend never to use the display name to identify and retrieve a parameter if you can avoid it.
In this single case, I do not believe you can.
Sorry about that.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
