Dynamo - Wall and Floor voids not deleting when not in use ?
Hi Guys,
I was using Mustafa Salaheldin dynamo graph with some tweaks of myself to create voids for the duct work and pipes.
The script as attached with this post and it works perfectly.
The only issue is - that when i change the duct position changes, the old wall void remains in place. The new voids get created perfectly in the new location.
Is there any way to leverage dynamo to delete these voids that are not in use due to change in location or sizes of the ducts or pipes?
Images showing the problem and script enclosed.
Thanks.
This is the Revit API forum, try here : https://forum.dynamobim.com/
Will do.
Thanks for the suggestion.
