How create arrow settings?
AndrewButenko
AndrewButenko
How add arrow to panel with revit api like a picture ?
Mustafa.Salaheldin
As far as I know there is now way through the Revit API. The closest approach is to create a SlideOut using AddSlideOut method.
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
AndrewButenko
Hi!
Do you have any example?
Mustafa.Salaheldin
Here you are
private static void AddSlideOut(RibbonPanel panel)
    string assembly = @"D:\Sample\HelloWorld\bin\Debug\HelloWorld.dll";
    panel.AddSlideOut();
    // create some controls for the slide out
    PushButtonData b1 = new PushButtonData("ButtonName1", "Button 1",
        assembly, "Hello.HelloButton");
    b1.LargeImage = new BitmapImage(new Uri(@"path\to\your\image\32x32.png"));
    PushButtonData b2 = new PushButtonData("ButtonName2", "Button 2",
        assembly, "Hello.HelloTwo");
    b2.LargeImage = new BitmapImage(new Uri(@"path\to\your\image\16x16.png"));
    // items added after call to AddSlideOut() are added to slide-out automatically
    panel.AddItem(b1);
    panel.AddItem(b2);
¯\_(ツ)_/¯
Mustafa Salaheldin
AndrewButenko
No arrow settings in this example.
Mustafa.Salaheldin
I was clear on that. You can't add arrow via API, but as an alternative you can use the slide out.
¯\_(ツ)_/¯
Mustafa Salaheldin
aignatovich
Hi @AndrewButenko!
It is not exposed in public API as @Mustafa.Salaheldin said, but that does not mean, you can't do it. There is a dark unofficial way to achieve this. You should reference AdWindows.dll and UIFramework.dll and execute something like the code below. Be careful to use Revit API in CommandHandler, you are not in safe mode at this point. You should register EventHandler and raise it. Look at Samples\ModelessDialog\ModelessForm_ExternalEvent from Revit SDK
	var tab = Autodesk.Windows.ComponentManager
		.Ribbon
		.Tabs
		.First(x => x.Title == "Manage");
	var panelSource = tab
		.Panels
		.Select(x => x.Source)
		.Single(x => x.AutomationName == "Project Location");
	var ribbonButton = new Autodesk.Windows.RibbonButton
			Id = "MY_DIALOG_LAUNCHER",
			Name = "My launcher",
			Text = "My launcher title",
			IsEnabled = true,
			CommandHandler = new RelayCommand(o => true, o => MessageBox.Show("dev"))
	panelSource.DialogLauncher = ribbonButton;
// ..... public class RelayCommand : ICommand { private readonly Predicate<object> canExecute; private readonly Action<object> execute; public RelayCommand(Predicate<object> canExecute, Action<object> execute) { this.canExecute = canExecute; this.execute = execute; } public event EventHandler CanExecuteChanged { add { CommandManager.RequerySuggested += value; } remove { CommandManager.RequerySuggested -= value; } } public bool CanExecute(object parameter) { return canExecute(parameter); } public void Execute(object parameter) { execute(parameter); } }
