View titles based on sheet location (grid location)
Typically view titles go on a sheet and number both numerically and sequentially (revit does this automatically). How do we set it to base the view title, based on sheet placement (see attached), I would like to go with the sheet format attached. we would just propose the names based on the numbers and letters shown.
If you could help i will be very grateful
BenoitE&A
Hey iwilson,
So we don't know much about your process of creating sheets:
1) let's assume you have people in your company who create them. Then you can create an add-in or a macro modifying the names while they are done, to respect your policy.
Your add-in will look like :
// Filter in all views to get the sheets you want
FilterElementCollector collector = new FilterElementCollector(uidoc.Document, uidoc.ActiveView);
collector.OfClass(typeof(Autodesk.Revit.DB.ViewPlan));
// Start transaction to be able to modify
using (Transaction t = new Transaction(uidoc.Document, "Renomme les vues selectionnees"))
t.Start();
foreach( Element e in collector)
// Convert to viewPlan
ViewPlan vp = e as ViewPlan;
using (SubTransaction subt = new SubTransaction(uidoc.Document))
subt.Start();
vp.ViewName = theNameIWant;
subt.Commit();
t.Commit();
2) if you create your views programmatically you can insert this piece of code
Have fun !
Benoit
Benoit FAVRE
CEO of etudes & automates
www.etudesetautomates.com/
