Rebar error
Rebar error
Arciviz
Rebar error
Arciviz
I have tried rebar. Unable to create.
Please refer attachment.
In Method 1 (Rebar.CreateFromCurves) work without error but rebar not found.
In Method 2 (Rebar.CreateFromCurvesAndShape) shows ERROR "RebarShape does not match curve";
pt0,pt1,pt2 & pt3 creates correct curve. That matches with Shape code "21".;
I don't know, Where I made mistake. Please help me.
View cu_view = ui_doc.ActiveView;
                  Element elem = Beams_Data_Lst[0].beam;
                  double left_bearing = Beams_Data_Lst[0].Left_Bearing,
                        right_bearing = Beams_Data_Lst[0].Right_Bearing,
                        Bm_depth = Beams_Data_Lst[0].Beam_Depth,
                        Bm_width = Beams_Data_Lst[0].Beam_Width,
                        Bm_cover = Beams_Data_Lst[0].Beam_Cover,
                        Bm_cut_len = Beams_Data_Lst[0].Beam_Cut_Length,
                        cover_Left_Col = Beams_Data_Lst[0].Left_Column_Cover,
                        cover_Right_Col = Beams_Data_Lst[0].Rigth_Column_Cover;
                  XYZ LLpt = Beams_Data_Lst[0].left_Cent_pt - new XYZ(0 , Bm_width * 0.5 , Bm_depth * 0.5);
                  XYZ pt0 = LLpt + new XYZ(-left_bearing + cover_Left_Col , Bm_cover , Bm_cover),
                     pt1 = pt0 + new XYZ(0 , 0 , Bm_depth - 2 * Bm_cover),
                     pt2 = pt1 + new XYZ(left_bearing - cover_Left_Col + Bm_cut_len + right_bearing - cover_Right_Col , 0 , 0),
                     pt3 = pt2 + new XYZ(0 , 0 , -Bm_depth + 2 * Bm_cover);
                  KJU.draw.DrawCircle(ui_doc ,LLpt , 0.25 , XYZ.BasisZ);
                  KJU.draw.DrawCircle(ui_doc , pt0 , 0.25 , XYZ.BasisZ);
                  KJU.draw.DrawCircle(ui_doc , pt1 , 0.25 , XYZ.BasisX);
                  KJU.draw.DrawCircle(ui_doc , pt2 , 0.25 , -XYZ.BasisZ);
                  KJU.draw.DrawCircle(ui_doc , pt3 , 0.25 , -XYZ.BasisZ);
                  IList<Curve> curves = new List<Curve>();
                  RebarHookType hook1 = KJU.Filter.ElementFiltering(doc ,typeof( RebarHookType ), "Rebar Hook 90") as RebarHookType;
                  curves.Add(Line.CreateBound(pt0,pt1)); curves.Add(Line.CreateBound(pt1 , pt2)); curves.Add(Line.CreateBound(pt2 , pt3));
                  // Method 1 = Rebar.CreateFromCurves  ***********************
                  Rebar rebar = Rebar.CreateFromCurves(doc , RebarStyle.Standard , UpperBar_Data_Lst[0][0].BarType , hook1 , hook1 , elem ,
                     new XYZ(1,1,1), curves,RebarHookOrientation.Left , RebarHookOrientation.Right , true , false);
                  // Method 2 =  Rebar.CreateFromCurvesAndShape ***********************
                  //Rebar rebar1 = Rebar.CreateFromCurvesAndShape(doc , UpperBar_Data_Lst[0][0].ShapeCode , UpperBar_Data_Lst[0][0].BarType , null , null,
                  //   elem , new XYZ(0 , 0 , 1) , curves , RebarHookOrientation.Left , RebarHookOrientation.Right);
                  if(null != rebar)
                     rebar.GetShapeDrivenAccessor().SetLayoutAsFixedNumber(3 , Bm_width - 2 * Bm_cover , true , true , true);
Sudhan.
Mustafa.Salaheldin
Can you please provide a sample project file ?
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
Arciviz
Part 1. Getting input ->  completed working fine.
part 2. getting  schema data  from beams -> completed working fine
part 3. Rebar on structural frame(Beam) (issue with it)
please find attachment.
regards,
Sudhan
Mustafa.Salaheldin
I meant Revit project sample 🙂
¯\_(ツ)_/¯
Mustafa Salaheldin
Arciviz
That is in side the zip. Also find it in the attachment.
Arciviz
I have stored "ExtensibleStorage" as schema in Grid - E in revit sample model. All RebarBarType, RebarSHape, hook, etc are saved in family.
Arciviz
Solved My self. I made mistake in normal vector. normal Vector should perpendicular to Beam Longitudinal section.
