I went ahead and implemented a line-plane intersection method for you in The Building Coder samples:
https://github.com/jeremytammik/the_building_coder_samples/blob/master/BuildingCoder/BuildingCoder/U...
Here is the code:
/// <summary>
/// Return the 3D intersection point between
/// a line and a plane.
/// https://forums.autodesk.com/t5/revit-api-forum/how-can-we-calculate-the-intersection-between-the-plane-and-the/m-p/9785834
/// https://stackoverflow.com/questions/5666222/3d-line-plane-intersection
/// Determine the point of intersection between
/// a plane defined by a point and a normal vector
/// and a line defined by a point and a direction vector.
/// planePoint - A point on the plane.
/// planeNormal - The normal vector of the plane.
/// linePoint - A point on the line.
/// lineDirection - The direction vector of the line.
/// lineParameter - The intersection distance along the line.
/// Return - The point of intersection between the
/// line and the plane, null if the line is parallel
/// to the plane.
/// </summary>
public static XYZ LinePlaneIntersection(
Line line,
Plane plane,
out double lineParameter )
XYZ planePoint = plane.Origin;
XYZ planeNormal = plane.Normal;
XYZ linePoint = line.GetEndPoint( 0 );
XYZ lineDirection = (line.GetEndPoint( 1 )
- linePoint).Normalize();
// Is the line parallel to the plane, i.e.,
// perpendicular to the plane normal?
if( IsZero( planeNormal.DotProduct( lineDirection ) ) )
lineParameter = double.NaN;
return null;
lineParameter = (planeNormal.DotProduct( planePoint )
- planeNormal.DotProduct( linePoint ))
/ planeNormal.DotProduct( lineDirection );
return linePoint + lineParameter * lineDirection;
