How can I use the Schedule VIEW checbox "Blank row before data" from API ?
How can I use the Schedule VIEW checbox "Blank row before data" from Revit API ?
the API:
sortGroupField.ShowBlankLine = true;
 is NOT OK!
It's set sortgroup show blank row.
I need : set first blank row222.jpg
I  want to access to  appearance properties through API.
properties in Appearance tab of Schedule Properties
not Sort Group tab
sr
I have the same problem, I don't know how to solve it
IbrahimNaeem
AFAIK ,The appearance tab isn't available through the API and better to get the job done is to do a schedule template inside of your project and assign this template to your schedule and you're done.
Hope this helps.
Thanks, Ibrahim Naeem
sr
thanks, but I still want to solve it with API.
