Creating a new DraftView
t.galland
t.galland
Hey,
I'm trying to create a DraftingView so I used this code :
using (var tx = new Transaction(document, "Create View"))
    tx.Start();
    var viewDraftType = new FilteredElementCollector(document)
          .OfClass(typeof(ViewFamilyType))
          .Cast<ViewFamilyType>()
          .FirstOrDefault(q => q.ViewFamily == ViewFamily.Drafting);
    if (viewDraftType == null)
        tx.RollBack();
        return;
    var draftView = ViewDrafting.Create(document, viewDraftType.Id);
    if (draftView == null)
        tx.RollBack();
        return;
    draftView.Name = $"{Init.Gui.MainView.ChartTitle}_Histogramme";
    draftView.Scale = 1;
tx.Commit(); }
 I tried with this post but I got a null value with the filterdelementcollector. Any idea ?
Thank you !
FAIR59
You can use the default ViewTypeDrafting:
var draftView = ViewDrafting.Create(document, document.GetDefaultElementTypeId(ElementTypeGroup.ViewTypeDrafting));
t.galland
I tried your code but I got this error (using a Try/catch) :
viewFamilyTypeId is not a valid ViewFamilyType for a drafting view.
Parameter name: viewFamilyTypeId
EDIT :
I tried with a new empty revit file and it worked. Can the file be "draftview lock" ?
t.galland
I tried differents tricks and here is what I got. My project doesn't have DraftingView familly. When I manually create a DraftingView it create a detail view...
I'll search how to fixe that.
If you have any idea ?
Thank you !
Revitalizer
you could use ElementTransformUtils.CopyElements to get the necessary type from another document.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
