pickobject
pickobject
pickobject
I can use prompt the user to select an element from the linked revit model:
Reference refElemLinked;
                try
                     refElemLinked = uidoc.Selection.PickObject(ObjectType.LinkedElement, "Please pick an element in the linked model");
                catch (Exception exq)
I can use prompt the user to select an element from the revit model:
                try
                     refElemLinked = uidoc.Selection.PickObject(ObjectType.Element, "Please pick an element in the linked model");
But how do I prompt the user to select an element irrespective of the main model or the linked model.
Thanks & Regards
Sanjay Pandey
htlcnn
You should use PickElementsByRectangle: http://www.revitapidocs.com/2018/ff8f9e7f-cc92-fe92-6ea4-9f1b581f2bac.htm
Because PickObject only allows 1 ObjectType, and Enum can not be inherited from two other Enums
RPTHOMAS108
There is a two stage picking approach for single objects that could be adopted as below. It's not overly clunky, I work with what I have.
This is kind of an illusion because you can first pick any link and then pick an element from any other link.
It is probably possible to limit the second selection to an element in the original picked link using the ISelectionFilter. i.e. if you try to find the element based on UniqueID and it isn't found then element was not from that document, so return false.
If you were picking multiple elements then it would be PickObject followed by PickObjects.
    Public Function Execute_TwoStepPicking(ByVal commandData As Autodesk.Revit.UI.ExternalCommandData, _
                           ByRef message As String, ByVal elements As Autodesk.Revit.DB.ElementSet) _
                           As Autodesk.Revit.UI.Result
        Dim IntApp As Autodesk.Revit.UI.UIApplication = commandData.Application
        Dim IntUIDoc As Autodesk.Revit.UI.UIDocument = commandData.Application.ActiveUIDocument
        If IntUIDoc Is Nothing Then Return Result.Cancelled Else
        Dim IntDoc As Autodesk.Revit.DB.Document = IntUIDoc.Document
        If IntDoc Is Nothing Then Return Result.Cancelled Else
        Dim R As Reference = Nothing
        Try
            R = IntUIDoc.Selection.PickObject(Selection.ObjectType.Element, statusPrompt:="Select element or link")
        Catch ex As Exception
        End Try
        If R Is Nothing Then Return Result.Cancelled Else
        Dim El As Element = IntDoc.GetElement(R)
        If El Is Nothing Then GoTo notsurewhatyoupicked Else
        If El.GetType = GetType(RevitLinkInstance) Then
            Dim Rlnk As Reference = Nothing
            Try
                Rlnk = IntUIDoc.Selection.PickObject(Selection.ObjectType.LinkedElement, statusPrompt:="Select element in link")
            End Try
            If Rlnk Is Nothing Then Return Result.Cancelled Else
            Dim Li As RevitLinkInstance = IntDoc.GetElement(Rlnk)
            Dim LinkedDoc As Document = Li.GetLinkDocument
            Dim LinkedEl As Element = LinkedDoc.GetElement(Rlnk.LinkedElementId)
            If LinkedEl Is Nothing Then GoTo notsurewhatyoupicked Else
            MsgBox("You picked:" & LinkedEl.Name)
        Else
            MsgBox("You picked:" & El.Name)
        Return Result.Succeeded
notsurewhatyoupicked:
        MsgBox("Don't know what you picked.")
    End Function
Thanks for the response.
I implemented a simple and easy approach. Before processing I ask from the user that he wants to select from linked model or the main model.
if he chooses main model
                try
if he chooses linked model
                try
Thanks & Regards
Sanjay Pandey
