How can I retrieve parameters of View Sheet before it was created?
Shai.Nguyen
Shai.Nguyen
Hi Everyone,
I'm exploring the Revit 2022, especially Export PDF.  I'm curious that how can Revit access Parameters of ViewSheet, while my model doesn't have any Sheet?
2021-04-11 11_03_15-Autodesk Revit 2022 - UNREGISTERED VERSION - [TestQuickPrint2022.rvt - Elevation.png
architect.bim
Hi!
There are two main types of parameters that can be in a list of avalable fields:
  • BuiltInParameters
  • Project Parameters
BuiltInParameter Id can be obtained like this:
>>> ElementId(DB.BuiltInParameter.SHEET_NAME)
<Autodesk.Revit.DB.ElementId object at 0x000000000000002B [-1007400]>
Project parameter Id can be accessed either through ParameterBindings property or with FilteredElementCollector of class ParameterElement:
>>> iterator = doc.ParameterBindings.ForwardIterator()
>>> while iterator.MoveNext():
... 	print iterator.Key.Name, iterator.Key.Id
Occupant 26010
Hinge Set 217757
>>> for element in DB.FilteredElementCollector(doc).OfClass(DB.ParameterElement):
... 	print element.Name, element.Id
Occupant 26010
Hinge Set 217757
After you get necessary parameter Ids you can use them to create TableCellCombinedParameterData objects and pass them to SetNamingRule method of PDFExportOptions class.
Maxim Stepannikov | Architect, BIM Manager, Instructor
architect.bim
And another solution:
  • start Transaction
  • use CreateSheetList method to create temporary sheet list schedule
  • get all avalable schedulable fields and Ids of their parameters
  • put necessary parameter Ids somewhere (list, collection, dictionary, etc)
  • rollback Transaction
Shai.Nguyen
I understood your point and write by using C#
Dictionary<double, string> parameterDict = new Dictionary<double, string>();
Transaction tr = new Transaction(doc, "Create Sheet");
tr.Start();
ViewSheet tempVs = ViewSheet.Create(doc, ElementId.InvalidElementId);
foreach (var para in tempVs.GetOrderedParameters())
   parameterDict.Add(para.Id.IntegerValue, para.Definition.Name);
tr.RollBack();
Thank you.
