Meshing faces
Meshing faces
amir.aroesti
Meshing faces
amir.aroesti
I wonder if it is possible to mesh a surface and get all the x,y of the junction (like the picture).
the quality and the size of the small areas (triangle/rectangular) are not so important.
I took this idea from the "finite element" algorithm.
after I will have those junctions, I can "Ray" those points on the Z-axis vector direction and find out each point's height.
hope I was clear.
jeremy_tammik
The most straight-forward approach to this using the Revit API would be to use the Face.Triangulate method:
https://www.revitapidocs.com/2021.1/b571177c-1268-35cd-0be1-e19db29fcb20.htm
amir.aroesti
Thnaks @jeremy_tammik .
now ill look for some implement examples.
