How are changing beams the start and end point?
AD8080202
AD8080202
How are changing beam the start and end point ?
Thanks in advance
jeremytammik
This question has been answered here and elsewhere many times.
Please research before posting!
Normally, you can simply set the start and end point of the beam location line, as demonstrated by the FrameBuilder SDK sample:
R:\Samples\FrameBuilder\CS\FrameBuilder.cs(285):
/// <summary>
/// set location line to the Element
/// </summary>
/// <param name="elem">goal Element</param>
/// <param name="startPnt">start point of the line</param>
/// <param name="endPnt">end point of the line</param>
/// <returns>is successful</returns>
private bool SetLocationLine(ModelElement elem, XYZ startPnt, XYZ endPnt)
  LocationCurve elemCurve = elem.Location as LocationCurve;
  if (null != elemCurve && !elemCurve.IsReadOnly)
    try
      Line line = m_appCreator.NewLineBound(ref startPnt, ref endPnt);
      elemCurve.Curve = line;
      return true;
    catch (Exception ex)
      Debug.WriteLine(ex.ToString());
  return false;
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
