exporting multiple views to dwg previous selection
rodrigohbm
rodrigohbm
hi friends
I am developing an application for exporting to dwg a datagridview which contains a check.
view image
the idea is to export only the selection.
I appreciate the information.
thank you
(translate.google.com)
I think you need this:
foreach (DataGridViewRow r in dataGridView1.SelectedRows)
// do the dwg export
rodrigohbm
thank you......
This is my solution:
For Each rabbit As Object In sheetstodwg
dim todwg as new list(of elementid)()
If (rabbit.ToString) = (row.cells(1).value.ToString) Then
todwg.Add(rabbit)
activedoc.export(ruta, file, todwg, dwgexportoptions.getpredefinedoptions(activedoc, exportdwg))
End if
Next
