Revit Macro
Revit Macro
sujeev
Revit Macro
sujeev
Could somebody please tell me a tutorial for revit macro creation. I am new to c sharp. i have experience in autolisp, now i want to do something in revit also. i dont have a visual studio here. can i do the coding in the macro manager tool.
Thanks in advance
Sujeev
Yes you can use the Marco Manager.
There should be plenty of stuff out there to get you started.
https://www.augi.com/library/getting-started-with-revit-macros
http://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-B82AB3C9-5CA3-4DA6-A060-DB1C29290B11
Here are a couple of links. I would recommend you download the SDK also, that has plenty of useful information including the RevitAPI.chm file which has is a great guide to the API and the Classes etc.
Paul.
Or you can also learn Revit API usng Macro by going to Harry Mattison's course found here https://www.udemy.com/revitapi/
Note: I dont get a cut for this plug 😉
sujeev
Hi Thanks for the advice. Already went through the site. and find some
introduction videos also. I am getting a move on with coding as I succeeded
with creating some views related to the levels.
Currently stuck up with getting the levels in a checked list box. I got the
levels using the While & filteredelement code but just couldn't feed it in
the checkedlist box.
Still in the early days.. Any help is always appreciated.
Thanks and regards
Sujeev
