Host family property for some reason null
after creating a family on the face of the wall, the host family property for some reason null.
FamilyInstance instance = doc.Create.NewFamilyInstance(face, location, refDir, famsym);
why this could happen and what can be done about it?
I need to place the family on the edge of the wall. Using the method described above, I place the family, but it becomes the upper hand. In order for it to become as it should, I try to rotate it. But I can not find the membership of the family wall.
jeremytammik
Dear vadim,
Are you saying that you perform the following steps with the following results?
  • Place family instance on face of wall using NewFamilyInstance(face, location, refDir, famsym); Host property points to wall.
  • Rotate the instance 180 degrees using the rotate method; Host property becomes null.
http://www.revitapidocs.com/2018.1/634dc711-7d00-a176-9c61-c53c27c89849.htm
Please provide a minimal reproducible case, e.g., a model containing just the wall and the family instance, rotated and unrotated, and a macro showing the code to create that situation:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Then the development team can take a look and see what is going wrong, if anything.
Thank you!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
I work with a big model. These are several rooms. I can not load the model in which the room is located, because there are 70mb downloads on this forum. And my model is two Vail for 58 and 120 mb
