Unable to Get ScheduleType
Hello all,
I'm working with schedules, I need to know the ScheduleType information. Which I wasn't able to find by using Revit API and Revit Lookup. However, with Dynamo I can easily get the ScheduleType information as shown in the image below.
I'm wondering, is there any way I could get the same information from Revit API too?
Appreciate any help!
Thank you
~ Ali Asad
jeremytammik
Dear Ali,
Afaik, absolutely everything available in Python is open source.
Therefore, you can simply read the Python code to see how it is done and what API calls are used.
You can also easily translate the Python code to C#, VB, or any other .NET language of your choice.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
RPTHOMAS108
Refer to RevitAPI.chm
ScheduleDefinition.IsKeySchedule
ScheduleDefinition.IsMaterialTakeoff
Excluding above could also relate to MEP schedules. Have no experience of those but know they can be excluded from the possibilities by looking at:
 ScheduleDefinition.HasEmbeddedSchedule
ScheduleDefinition.IsEmbedded
(Depends what you count as a regular schedule I suppose).
