Hide all tab view document and restore
sizy458
sizy458
Hello ,
i have some file rvt opened and
i want to hide all tab view and show view 3d and elevation of one rvt document and tiled document.
And after i want to restore the tab hidden.
How do i do for hide and restore ?
For tile the tab view opened.
        internal static void TileView(UIDocument uidoc)
            //throw new NotImplementedException();
            var uiApp = uidoc.Application;
            if (uiApp != null)
#if v2019
                RevitCommandId commandId = RevitCommandId.LookupPostableCommandId(PostableCommand.TileViews);
                if (uiApp.CanPostCommand(commandId))
                    uiApp.PostCommand(commandId);
#endif
 Thank.
jeremytammik
I do not believe that the Revit API provides much direct support for these kind of operations, so I am afraid you are stuck with the Revit user interface functionality and the possibility to use PostCommand to launch built-in Revit commands, just as you point out yourself.
You may be able to make some use of the UIDocument GetOpenUIViews method to get a list of all open view windows, and the ActiveView property to get and set the currently active view of the currently active document:
https://www.revitapidocs.com/2020/b6adb74b-39af-9213-c37b-f54db76b75a3.htm
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
